Recently had cause to upload a fair few pics to my photo archive to use in some for sale adds i wanted to post. Originally intended to upload them all
at once but ran into an issue that made the process a real pain, if i was uploading a series of 23 or 4 pics in quick succession on more than one
occassion i would end up with someone elses pics instead of mine in my archive.
Im guessing that if more than one user uploads simulataniously the system loses the plot, anyone else come accross this? Also is there any improvmenet
to the photo uploading that can be made? for instance the ability to select multiple pics before uploading them?
Ta
As per one of your ads - Ive come across this here, and ended up with someones brake pics, but the thumbnail was my original picture, which when clicked showed the wrong one.
Its happened to me too in the past.
It's happened to me a couple of times... I think it might depend on the name you've given the pic as I've found that if I delete the problem pic and then rename it (radically), then it uploads / displays a-ok!
If you click on the BMW caliper pic on the homepage now, it shows two old rusty calipers
