I am unable to access the U2U function. I can post in threads, but can't get into my U2Us or send new ones. Any suggestions? Thanks!
Rob
its done as a pop up, adjust your browser to allow pop ups from this site only
Roger
You need to get a token from the shop.
In real life make sure your pop-up blocker is set to allow this site.
As above, check and adjust your browsers pop-up settings so the U2U pop-up can function.
That said, if it worked before and you've not changed the browsers settings it should still work. An automatic update may of course have changed
the settings for you. Installing an alternative browser may allow it to work if necessary.
