I'm trying to load photos into one of my folders but all I get is - you have an error in your sql syntax; check the manual that corresponds to
your mysql server version for the right syntax to use near )' at line 1
[Edited on 7/8/20 by andyfiggy2002]
Are you using any special characters in descriptions? i.e. ()[]/# If so then try and remove them first. If not then it's a bug with the forum code.
there are error pops up also when trying to load a file with the a non-unique name or one that is over 300k,.
[Edited on 7/8/20 by HowardB]
Mines a massive 430kb
