How do you get the little pictures to appear at the side of your profiles? My Computer skills are slightly below my mechanical skills, and I
don’t have a clue how to do it. Any smart comments from web heads should be emailed to www.eat myasswithaspoon.com.org.whatever.
hope this is simple enough:
You need to upload your desired picture to somewhere on the web (ie you need some webspace) then put the website address of that picture (the url)
into the avatar box under your profile
or, if you don't have your own webspace anywhere, then you can upload your pic to the photo section here and use the address of your pic there.
Mr thetankwad sir,
If you require instruction on "how" as the other guys have said then try reading my previous post on this thread a while back...>
http://forum.locostbuilders.co.uk/xmb/viewthread.php?tid=2903&page=3
It's the "Another way" one with the Stormtroopers taking some light relief to the side.
Hmm... having just read what I wrote there I forgot to say after right-clicking your picture, choose "Properties" from the menu and then
select and copy the full link that shows in the dialog.
HTH
[Edited on 25/4/2003 by andyd]
