keep getting this message when i try to post a picture using the browse button.
any ideas guys or remedies in non techy speak if poss.
This is the error mesage i get.
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's airbox
(Medium).jpg', 'image/pjpeg', '82431', 'ÿØÿà' at line 1.
It was ok but wont work now
Rich
bl--dy computers AAAarrrrhhhh
seems to have sorted itself out
Cheers anyway
Rich
I would expect you had a reserved char such as one of these ' which will break any sql being build up and executed as a string
