Guys, going nuts here, someone please explain how I attach an image from photobucket?
I know to copy the IMG code but where do I place it in the "post new topic" screen ??????,
cheers,
CT
Go into the "post reply bit, above the section you write in are 10 little squares, 4th one from the right says "insert an image". click
this then just paste in the URL from photo bucket.
Easy.
Originally posted by scotty g
Go into the "post reply bit, above the section you write in are 10 little squares, 4th one from the right says "insert an image". click this then just paste in the URL from photo bucket.
Easy.
no need to do it that way.
once you've copied the code just paste it where you want in your message
Under the image in Photobucket are 4 headers. The last one says IMG CODE. Place tour pointer on it and left click and it will say copied. When you are
typing your reply and want to add your picture press the Ctrl key and V at the same time to paste the image code in your reply. Keep your image size
down to about 600 pixels or people will shout at you
and always `preview` first!
