whats the difference in mcsorleys chassis's
lucky13 - 4/10/10 at 02:09 PM
From reading his website i find it hard to understand what the differences is in the 442 and 442e for example. Im 6 foot 3 and size 12 feet and i want the one with the most foot room. Does his chassis make the footwell bigger?
meany - 4/10/10 at 02:20 PM
442= 4" wider, 4" longer, 2" taller
than the standard Ron champion locost chassis.
there is also a +4 which is just 4" wider
not sure on the 442e
meany - 4/10/10 at 02:31 PM
the 442e has a wider front than the 442.
i have pdf files of all 3 chassis plans here, i'll see if i can find where i downloaded them from.
meany - 4/10/10 at 02:32 PM
here you go.
http://www.sevenesque.com/plans/
handyandy - 4/10/10 at 06:20 PM
The Haynes Roadster is 4 inches longer & 2 inches wider than the original Ron Champion chassis & also has Independant Rear Suspension as the main donor used is the Ford Sierra.
A few of the completed cars have tall drivers....1 of them is 6ft 7 tall & has no problems with the car, in fact thats why he chose to build the Roadster.
cheers
andy
