Indy Brake Pedal
Guinness - 21/5/08 at 12:10 PM
I'm converting my clutch over to hydraulic operation at the moment, which means I have my head stuck in the footwell for the first time in ages.
While I'm down there I was considering changing the position of the brake clevis slightly to increase the pedal travel and increase the braking effort.
My MK pedals look to be about 5mm thick steel x 25mm wide / deep (If you know what I mean).
It already has 1 no 8mm hole drilled in the pedal, will drilling another 10-15mm further up weaken the pedal / or even be worthwhile in terms of brake feel?
Mike
Bluemoon - 21/5/08 at 12:12 PM
You will want to move the hole down to increase peddle travel.. This would reduce peddle effort...
I would think the extra hole will be fine..
Dan
[Edited on 21/5/08 by Bluemoon]
Guinness - 21/5/08 at 12:22 PM
Thanks Dan!
That's what I meant, honest!
Mike
ReMan - 21/5/08 at 04:24 PM
I hope so
stevec - 21/5/08 at 06:24 PM
Perhaps fill the other hole with weld, but I think you will be OK anyway.
Steve.
chris_smith - 21/5/08 at 06:33 PM
depends if its floor mounted or not as to which way your going up or down
britishtrident - 21/5/08 at 06:40 PM
Be aware if you make the angle of the pushrod to the cylinder bore has a big effect --- you really can't move the hole by a significant ammount
RobH - 21/5/08 at 07:38 PM
I moved the clevis point on my pedal down about 3/4" and tilted the master cylinder so the push rod was still in line with the direction of the piston travel and it has mad a world of difference to the fell of the brakes (loads better)
Rob
[Edited on 21/5/2008 by RobH]
Bluemoon - 23/5/08 at 08:08 AM
Interesting Rob, the early MK indys had an angle block for the master cylinder, I wonder if this was why?
Dan
