I am after some 1/2" unf HALF nyloc nuts.
I have tried local suppliers, Namrick, Ebay, and I have looked on the net.
I am after about 20
cheers wasa
I will be going to my local nut/bolt expert on weds for a load of 1/2"UNF stuff.... I can see if he has them and get them if he does? U2U me on Tuesday evening if you still need them and I will see what I can do!
I am after about 20
cheers wasa
cheers Tegwin.
Flak, I have a bag full of standard ones and have skimmed a few and yes they will do the job but I would sooner just have the half nuts
not sure if you can get half nuts with nyloc .
try mcgill motorsports
http://www.locostbuilders.co.uk/viewthread.php?tid=90711
hmmm
try b&q or dixon hall
Get some std ones and skim them in your lathe to the thickness you need?
Lathe? That's for wimps. A locoster would get some coarse W&D and lap them down to the required thickness in a couple of days!
Yes they do make them. They use them on the maxi ball joints for a start.
nice one, this site does have every answer.
