Hi all
Decided I needed a bigger boot so my Mondeo is up for sale
http://www.autotrader.co.uk/classified/advert/201236484042887/sort/default/usedcars/make/ford/onesearchad/used/onesearchad/nearlynew/onesearchad/new/q
uicksearch/true/page/1/radius/1/postcode/ip38gn?logcode=p
I've used to tow a few times and it's mostly had long journey use as I walk to work.
Thanks!
Ed
Need a bigger boot? Crikey! I thought the boot was massive!!! You need a van then! good luck!
Thanks! I decided I really need an estate shaped car for loading a weekend of race kit so thought the boot is only a little bigger fore-aft,
it's wider and squarer. Also a bit more power for towing a bigger trailer.
Ed
Also now an eBay auction with a fairly low reserve
Linky
Ed
