Just sold my Narrow body Westfield.
I am looking to replace it.Is there a kitcar that is as narrow as the Westfield but with more generous seat space as SWMBO doesnt fit anymore.
Gratefull for any help,apart from the obvious ....divorce!
EH? Why did you sell it if you want a one the same!
McSorely does plans where you can choose width and lengths
You could keep length/wheel base but increase width
Thanks for the advice boys
leave her at home
even better get a single seater
seems contradictory in terms the same wheel base but wider seats, the body width generally defines the wheel base for example the MScorley is wider than an MK which is wider than a Caterham. most kits that use the Sierra running gear and drivetrain should be wider you also need to consider the seats being used. A fibreglass seat gives less room than a seat squab
