ive just got my carbon modz front cycle wings out of storage,and one of them has twisted out of shape.is this normal for carbon fibre?
The next question is can i untwist it by applying heat or will it damage the cycle wing?
Chris
It is unlikely that heat will halp you, as the resin is a thermoset, not a thermoplastic. If they are warped, unless you have stored them badly then the layup (the design) is probably dodgy. I would ring them and ask them to exchange them for another pair. If they won't ask them for the layup (the order and stacking sequence of the layers), and I will tell you if that is the problem!
the other problem is i got them from stonleigh last year!and just got around to fitting them.
If the twist comes out by hand will the bracket hold them in the correct position so they look symmetrical when they are on the car?
one of them is a member on here i believe, might be worth a u2u if you dont get anywhere. Not been on for a while though. link
