Scumbag college....Your starter for 10,i have a switch rated at 3 amp at 240V A/C and 5 amp at 125V A/C,how many amps would it handle at 12V D/C ?
It should be fine up to the higher rating (5 amp):
link
depends more on if the load is inductive and how big the contact gap gets when you switch it off.... try it and see!
i knew it wouldnt be easy....plan B it is then,cheers chaps
