Sorry - another refit kitchen question!
Glass splashbacks seem to be crazy money and I was wondering how feasible it might be to make my own?
Have glass cut to size and then paint the back of the glass? Would only want a plain colour and I'd like to cover a panel that's about
2000mm by 500mm but could be done in multiple pieces?
Am I going clinically insane or does this sound like a plan?
shouldnt see why not, it would have to be toughend or laminates with ground edged unless you are using an edging strip. You would also need a lot of prep to get the painting to look good you may be better having vinyl applied as it would look more consistent.
Originally posted by McLannahan
Am I going clinically insane...?
sounds fair.
get it frosted for a key, then spray it?
you've got me thinking about my kitchen now.....
before you make your mind up have a word with these guys,
they are over the road from me.
COLOURED GLASS UPSTANDS SPLASHBACK SPLASHBACKS on eBay (end time 06-Feb-11 13:23:58 GMT)
Yes!
By the time you get the glass cut (including all the holes for sockets/switches etc) and get the paint right, you won;t be far off the cost of an off the shelf splash back.
The idea occurred to me some time ago and I did all the costing up and decided that it really wouldn't be worth all the effort and 80% of the cost to achieve something that's only 50% of the end result.
You can get drill bits for glass
up to around 7mm in diy places which is okay for screws. I don't know what sort of paint would be best but I've used blackboard paint,
normal gloss and normal emulsion on the backs of fish tanks and it doesn't stay as a perfect finish for long, yet it's a pig to get off and
redo.
I know it's a bit retro, but I did mine in satin stainless steel. looked ok and for £200 was much cheaper than the shop stuff. Local fab shop cut
it for me.
hope that helps
I got my glass one at IKEA.
We have just been through this....
Got our new kitchen being fitted in February and went from a Stainless brush steel splash back (which actually shows load of marks and is a pain to
clean) ,, to considering Glass. But in the end for us, we went for a matching Granite one, it will match the worktops and was not that much more than
a Glass Splash back of the same size.
I did really like some of the "cracked glass" designs out there though. A mind boggling choice of styles and finsihes.
[Edited on 19/1/11 by karlak]
