Just a warning
Next door's drier has just gone up in flames and burnt / damaged the garage and all contents
Don't leave them when in use
ironic timing i just took ours out of the garage to be taken to the tip yesterday useless spacetaking things things they are
Ours goes for hours in the garage!
Why? A clothes line and some pegs does a much better job and minim running costs.
Clothes line is fine when the weather is good and you are around all day, but it's not much good if you have to put the clothes out first thing in the morning and then go to work, only to come home at the end of the day and find that the weather has changed. Certainly no good in the winter and we'd rather not be trying to dry clothes for the five of us, in a hurry, in front of the fire.
we had this happen to us about 8 years ago. I took it apart to look and found a design fault (inlet drawing from exhaust and building fluff up on red hot heater elements) and raised it with them and got a full refund 21/2years after we bought it. No argument just a straight offer of new replacement or the money back.
Coincidently I had ours apart yesterday, trying to cure a nasty squeal that has developed.
I blew all the inside clean with an airline, luckily a windy day and 10bar or air did a great job. But to be honest there was very little buildup,
except around the seals where a new, "fluff seal" had formed. Actually I thought it was the original seal it was so uniform and dense!
That is an 8 year old hotpoint.
Years ago had a white knight. Took that apart to find the inside had a layer a good inch plus thick, and all had black scorching. A decent clean, and
repeated every year until it died, kept that OK. Goodness knows how old it was when we got it (hand me down)
I do wonder if the condensing driers suffer more?
I remember ,my Fire Marshall training and the trainer on the day said that tumble dryers and dish washers are very high up the list of house fires, he
said don't leave the house with them running, a tumble dryer if not cleaned out after every use cusses high amounts of static and has been known
to set alight the fluff that is left behind in the filters, so be aware,
Dangerous things if not maintained or cleaned,
