im part of a team that got accepted into the redbull soap box derby this year in london, my job is to build every thing that wont be seen: chassis,
wheels, brakes, steering etc,
i dont have very long to build it and have decided to go with suspension, double wishbones on all corners,
heres where i need help from the vast knowledge of locostbuilders,
what spring rate should i go for?
i was thinking i would use shocks from a pit bike or quad, about 280mm eye to eye, maybe 200-250lb
the soapbox will weigh 80kg and have 2 people in it.
i will be using 12-14 inch pit bike wheels.
anybody have any ideas on this or any other advice, ive not built one before.
thanks Danny, (team turtle heads)
we have a twitter and facebook page to follow progress , or vote for us on the red bull website.
Originally posted by dano...I've not built one before.
suspension.... how about MTB rear shocks? a lot of which can be locked out when not needed as well, simply by flicking a little lever
Travel will depend on the pivot points, mtbs tend to have between 100-200mm suspension travel.
You can also dial them to the stiffness you want via air chambers and a high pressure pump.
Rebound can be adjusted, and preload.
http://www.ebay.co.uk/itm/W503-FOX-DHX-3-0-REAR-SHOCK-COIL-MTB-SUSPENSION-245-MM-X-70-MM-/161683162622?pt=LH_DefaultDomain_3&hash=item25a51145fe
r />
one of them on each corner?
good luck to
http://www.redbullsoapboxrace.com/uk/en/team/turtle-heads/
for
tomorrow, SUNDAY 12th
coverage on 'dave' from 6pm...
I've just been watching 2014 Red Bull soapbox racing on Dave this evening, looks like a lot of fun. There were a couple nasty looking accidents,
though everyone seemed to walk away relatively unscathed.
Best of luck for the OP
