Cloudy headlights
liam.mccaffrey - 2/9/08 at 06:58 PM
my headlights on my mini-van type effort thingy-me-bob have gone really cloudy and are dimming the lights significantly
I priced up what i can only assume were new solid gold ones from the motor factors
does anyone thinck i will be able to polish the clouds off with a mop and some cutting compound or something. they are plastic btw
[Edited on 2/9/08 by liam.mccaffrey]
COREdevelopments - 2/9/08 at 07:39 PM
i tried that out on a yaris, came up ok and worked better. so why not give it a try.
rob
Mark Allanson - 2/9/08 at 07:54 PM
We repair lightly scratched headlamps at work by flatting with 1000 and then 2000 and then G3 on a polishing mop, works a treat
zetec7 - 3/9/08 at 04:58 AM
I've used 1000-grit wet sanding, followed by a commercial plastic polish, with great success. If you're careful, it will come out clear as glass.
melly-g - 3/9/08 at 06:55 AM
Use toothpaste!! this works ok, mate done it on a vitara good as new now.
BenB - 3/9/08 at 10:56 AM
Second the toothpaste. Fairly gentle so you'll struggle to make things worse (which could be easy with stronger abrasive pastes)...
