As per the title, all of a sudden, went to move of and I have a box of neutrals!
- Felt odd, stiff, couldnt get any drive anywhere.
- Stopped, jacked car up, prop and diff where fine.
- Shift started feeling normal again, but only engages 5th.
I am told 'there is a roll pin in the top that sometimes goes' and its most likely that. Sadly I think the box (and hence engine?) will have
to come out, but once out, what sort of a size of job are we talking, top of, half and hour, done. Or get a new box and sort it over the winter.
Thoughts, suggestions, photos of the offending item?
Daniel
Take the gear stick out and see if the saddle is OK. That's the weak link in the system.
could be this HEAVY DUTY RACING SPEC&apos' GEARLEVER SADDLE CLIP FOR FORD TYPE 9 &' ROCKET 4GEARBOX
as coozer said worth a look
The sticks on a remote shifter, looks like the one in the link below, and all of that does totally hunky dorry. I have one of the red saddles with me,
and will try it with the gear stick direct into the box (extension removed) but I really don't think its the issue given how it felt when it
failed.
WESTFIELD CATERHAM 7 DAX LOCOST SIERRA 5 SPEED TYPE 9 GEARLEVER EXTENSION MLR.NC
Daniel
all gears exept 5th uses the main box slector (5th is in the tail housing)
take the box out and remove the lid and look down at the selector and move it into 1-4th
there is a roll pin that holds the the bit that moves the selector forks onto the selector shaft but you will have to see if its possibe without
stripping the gearbox. the little finger bit also has been known brake off
Originally posted by baz-R
there is a roll pin that holds the the bit that moves the selector forks onto the selector shaft but you will have to see if its possibe without stripping the gearbox. the little finger bit also has been known brake off
IIRC there is a donut shape magnet at the bottom of the later type9's with any luck its stuck there
when looking at the underside you see a bit of casting that looks like there was a bit that could have had a drain plug if it was drilled and tapped
by ford, its not its where the magnet lives.
it may be possibe to hook it out with the gears still in place if your lucky?
when looking at the underside you see a bit of casting that looks like there was a bit that could have had a drain plug if it was drilled and tapped by ford, its not its where the magnet lives.
Stupid question, but where should I be going for a new roll pin.
I understand it is 5x20mm, but dont expect all roll pins are equal, and am obviously keen to prevent premature failure.
Will this do the job?
http://cbradleymotorsport.co.uk/transmission-drivetrain/gearboxes/quaife/gearbox-spares/type-9-dogbox-roll-pin-5x22.html
Daniel
When you have the new roll pin in place use some decent lockwire to secure it in place
[Edited on 17/9/14 by rusty nuts]
I would think a normal rollpin size was used by ford.
It could be metric or imperial and only need bevan long as the total hole length.
Lock wire can be passed down the hole when it's fitted and looped around the outside to stop the pin shaking out.
I've had several roll pins come out over the years even when they have been new when fitted. Locking them with wire stops them moving. I
wouldn't be surprised if the
OP roll pin broke due to partially coming out of the selector/shaft
quote:I expect so too, I don't have the ability to accurately measure the hole, but with it in the hole I have measure I have measured the diameter of the half I have left to be 4x20mm which is at odds with the above link suggesting 5x20mm however from a post on WSCC I have also seen recommendation that BGH geartech can and will supply pins, including a second pin of the right size to go inside the first, so that is my plan, along with some lock wire!
I've had several roll pins come out over the years even when they have been new when fitted. Locking them with wire stops them moving. I wouldn't be surprised if the OP roll pin broke due to partially coming out of the selector/shaft
Hope it's sorted now
