balidey
posted on 31/7/09 at 10:47 PM |
using search and odd results
This may be me being a bit thick, but how does the search facility work?
I have a couple of times in the past searched for something, not found what I want and then had to ask. Then only to be given a link to what I
couldn't find.
Now let me give you an example. I recently wanted to search for 'round chassis tube' info. And it gives 3 results only.
yet when i type in 'round tube chassis' it gives all the results I wanted, hundreds of them.
So what are the rules for searching? Does it search for those words in that phrase? Should I be using quotation marks?
i thought the search just looked for those words,i didn't realise there was a rule to the order they are in.
Andi
posted on 31/7/09 at 10:56 PM |
Not quite sure but it can be a bit of a P.I.T.A.
Once you do get the results I find you have to right click on the subjects and select open in new tab or window, otherwise its a bit of a mission to
get back to the results page
chris_smith
posted on 31/7/09 at 10:57 PM |
i believe it searches for the word/words as you type them, eg if you search "carb" it will find all posts with that word, if you search
"xflow carb" it will search all posts with those 2 words as they are typed, im hoping this is right, but if wrong someone will be along
soon to correct me.
chris
balidey
I can get back to the results fine (using firefox on ubuntu is much easier for that) but its the getting of the initial results that i am struggling
with. All other forums I use you can just type in 3 words in any order and you get the same results, but not on this forum
chris_smith
posted on 31/7/09 at 11:08 PM |
what is it your trying to search?
Fozzie
posted on 31/7/09 at 11:35 PM |
Try reading through this thread...
Works great in FireFox too...
http://www.locostbuilders.co.uk/viewthread.php?tid=80416
HTH Fozzie
UncleFista
posted on 1/8/09 at 12:26 AM |
Try using a percentage sign "%" instead of a space between the words you're searching for.
Works for me, of a fashion
Tony Bond / UncleFista
goodguydrew
posted on 1/8/09 at 08:10 AM |
I use google homepage advanced search.
bmseven
posted on 10/8/09 at 05:04 PM |
Good tip allways found this search a PITA
but that seems to work
