David Jenkins
posted on 12/4/05 at 07:02 PM |
"Back" command annoyance
Chris,
This is not so much a problem - more an annoyance.
When I'm going through the forum I go in and out of sub-forums a lot. When I've finished reading in a sub-forum I use "back"
to return to the main forum.
Trouble is, each time I return from one of the lower sub-forums (like this one) I end up at the top of the page. So I end up with:
scroll down main forum
open sub-forum
read messages
"back"
open next sub-forum
read messages
back
open next sub-forum
and so ad infinitum.
In some other forums I have visited the "back" command returns you to the view you had before you went into the sub-forum. This makes
viewing the list so much faster and much less annoying.
Is there some parameter you can set, to enable "return to the view you left earlier"?
rgds,
[Edited on 12/4/05 by David Jenkins]
flak monkey
posted on 12/4/05 at 07:20 PM |
Mine already does what you suggest....and i havent changed anything in the options.
Click back and you are taken to the view you left on the previous page (if that makes sense)
Sera
http://www.motosera.com
James
Works alright for me mate- just tested to be sure and 'Back' goes to the original view!
You could always up your resolution so you don't need to scroll down!
James
EDIT: Ya beat me to it!
[Edited on 12/4/05 by James]
- Muhammad Ali
Smooth Torquer
posted on 12/4/05 at 07:26 PM |
Different browsers!
I know the issue your talking about, and have noticed that it works in IE but not in Firefox, which is annoying as I mainly use Firefox.
Sam
Deckman001
posted on 13/4/05 at 07:15 AM |
I have the same problem today , but last night it was 'to last place', it seams to change depending on what mood it thinks I'm in !!
Jason
David Jenkins
posted on 13/4/05 at 09:30 AM |
Bugger! Not another bit of IE-tuned software!
That really annoys me...
Although I guess it's more to do with the forum software that Chris is running, not a programming choice that he's made. Mind you, he is
running this via Apache on Linux, so there's no real excuse!
