<<  1    2  >>
Author: Subject: Preparing for IVA
big_wasa
posted on 2/1/12 at 08:57 AM Reply With Quote
Re belt covers.
There is a little tag either side of the cover. I have drilled a 3mm hole in each tag and looped a tie wrap through it.
Secure and looks great. There will be no need for it to drop of after iva.
chris666
posted on 2/1/12 at 08:24 PM Reply With Quote
I may be wrong but do you not need some kind of support for your head ?
Because your seat backs are low.
6.
A system of head restraint must be fitted on every outboard front seat.
Chris
[Edited on 2/1/12 by chris666]
Dave Bailey
posted on 2/1/12 at 09:08 PM Reply With Quote
Chris,
The seats are the standard Cobra high backs so should be ok......
big_wasa
posted on 2/1/12 at 09:22 PM Reply With Quote
That will be my pic showing covers but minus headrests
spiderman
posted on 2/1/12 at 10:16 PM Reply With Quote
Originally posted by Chippy
Originally posted by Dave Bailey
I have closed the underside of the dash off......
Dave B.
Yes so did I, but still needed to be 38 mm rounded edge, or padded!. Cheers Ray
That it was 19mm not 38mm or has it changed, or did I read it incorrectly?
Spider
Chippy
posted on 2/1/12 at 10:54 PM Reply With Quote
38mm diam, 19mm rad. Confused myself there, :-) Cheers Ray
spiderman
posted on 3/1/12 at 12:52 AM Reply With Quote
Bugger I've fitted a 19mm tube to the bottom of my dash so I quess that will have to be padded then.
Although looking at other peoples photos theirs look to be a smaller radius than mine so I am confused. Bloody IVA,
could have had my car finished ages ago if it was not for the stupid projection rules and minor saftey crap and at far less cost. I do believe in structural safety/rigidity like the NZ test, as they crack test welds and inspect the car during the build up but rules such as not having a sharp edge on the exhaust outlet is a no no but okay to get 3rd degree burns from it.
Spider
<<  1    2  >>
