<<  1    2  >>
Author: Subject: Sale of unstarted project
BenBrooks
posted on 9/5/19 at 04:49 PM Reply With Quote
u2u sent
1960dave
posted on 9/5/19 at 06:35 PM Reply With Quote
Would you post one of the exhausts?
nye
posted on 9/5/19 at 07:43 PM Reply With Quote
Are driveshafts modified to fit? If so would you post?
scutter
posted on 10/5/19 at 11:19 AM Reply With Quote
u2u's replied to. Drive shafts aren't modified as wishbones made wider.
Dan.
scutter
posted on 10/5/19 at 11:34 AM Reply With Quote
More bits.
Meagsquirt V2, set up for V6 with wasted spark, knock input and has a USB input, comes with wideband sensor/guage and knock conditioner. £400
Alfa Romeo V6 engine, balanced, heads skimmed to 11 to 1 comp ratio. comes with downpipes, desno alt. requires water pipes to T stat, clearances set and rocker covers fitted. has flywheel to take direct attached gearbox not transaxle. £500
Borg Warner T5 gearbox, modded bellhousing for Alfa Engine which can be unbolted for fitment of Ford bellhousing. Ratios looked up, it came from a 2wd sierra cosworth. £750
Regards Dan.
[Edited on 10/5/19 by scutter]
CeeBee
posted on 11/5/19 at 08:35 AM Reply With Quote
Windscreen Pillars
Hi Dan,
Please could I buy the windscreen pillars.
How do you want payment?
Regards
Chris
scutter
posted on 11/5/19 at 08:57 AM Reply With Quote
Chris, please check your u2u messages.
Dan.
scutter
posted on 19/5/19 at 10:01 AM Reply With Quote
Now on the EBay
Dan.
wowblaauw
posted on 19/5/19 at 10:24 AM Reply With Quote
Dan, just to let you know, I received the oil thermostat, thank you very much,
very happy.
Craig
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
scutter
posted on 19/5/19 at 10:28 AM Reply With Quote
Not received fella.
Dan.
scutter
posted on 19/5/19 at 10:33 AM Reply With Quote
You're welcome fella.
Dan
<<  1    2  >>
