bigfoot4616
posted on 31/3/09 at 09:10 PM |
battery cable
anyone any idea what size cable i should get for the battery connections on a BEC
cheers
jambo
posted on 31/3/09 at 09:56 PM |
think its 6mm.
check out vehicle wiring products.
good fast service.
bigfoot4616
posted on 31/3/09 at 10:43 PM |
yes, i've used them a few times.
there smallest size is 7.5mm OD so i think i will just go for that. its 16mm2 and rated to 110amps
Land Locked
posted on 1/4/09 at 05:57 AM |
The important thing is the length of the wire. 12 Volt DC suffers from voltage drop on thinner cables over longer distances.
So the 16mm square is a good choice for a short run, if the run is longer go thicker.
dhutch
posted on 1/4/09 at 11:50 AM |
My cvh is on 16mm^2. Although the round trip lenght is all of about 1m.
Daniel
bigfoot4616
posted on 1/4/09 at 05:54 PM |
cable length will be less than 1m so looks like the 16mm2 will do
cheers
