NS Dev
posted on 8/4/09 at 08:03 PM |
How to move a 2 post car lift
Right, looking at a Bradbury 2103 2 post lift.......
first off, anybody know what they weigh? I'm guessing around 750kg all up.
How much do the individual pillars weigh, and any ideas how to get them onto a car trailer without too much hernia?
Also, how long have these been around for and what goes wrong with them (guessing lift nuts and thats about it?? )
speedyxjs
posted on 8/4/09 at 08:12 PM |
Just my opinion but i never feel safe under a 2 poster. They always look like they are about to topple over when having to undo stubborn nuts etc
Dave Ashurst
posted on 8/4/09 at 08:22 PM |
These guys could probably answer, and they're based in Bedworth - so not far.
You probably know them already?
http://www.garageequipmentdirect.co.uk/index1.html
NS Dev
posted on 8/4/09 at 08:23 PM |
have you worked under a 4 poster? They are always in the way!
Land Locked
I'm always tempted to give a simple reply like "very carefully".
Without toys like overhead cranes, a wheeled engine crane and straps to lay the posts flat, same to lift at centre of gravity and load flat onto a
trailer. One could replace the lifting gear with many hands, but it's much easier on the back to use the crane.
(wish I had space for a 2poster in my home workshop)
[Edited on 8/4/09 by Land Locked]
NS Dev
posted on 8/4/09 at 08:27 PM |
really was a case of, "anybody else done it?" and "how many bodies do you need to lift it?" I'm guessing 4 but I really
don't know!?
speedyxjs
posted on 8/4/09 at 08:28 PM |
Yeah. I think the scissor ones are best but they are really expensive atm
NS Dev
posted on 8/4/09 at 08:29 PM |
Ps, Dave, yep I could go there, no, never come across them before but thanks for the tip, may be useful for spares.
We were looking at possibly spending £700 to a grand on a used lift, but now found one for £200 that "seems ok" but its a good few miles
away and I'm trying to hatch a plan for pairs of hands required!
Mal
posted on 8/4/09 at 08:37 PM |
I've Done it
5 weeks ago I bought a second hand 2 post lift. I removed the motor from one of the columns to lighten it. Then the columns were unbolted from the
base.
3 of us were able to manually lift the columns and the base frame into my box trailer. Once home I used my manual hoist to lift the components from
the trailer on my own.
So, easily do-able.
Mal
Danozeman
posted on 8/4/09 at 08:39 PM |
4 men to lift it. If the posts have the motor on the top theyl be f'ing heavy.
When we had our Tecalemit 2 poster moved at work the post with the motor on fell on a bloke and dam near broke his leg. They were moving it with 2
people and it took 4 of us to lift it off him and stand it up again.
So if you can lay it down and take the motor off.
Dan
NS Dev
posted on 8/4/09 at 08:52 PM |
Its dismantled into the base "h-frame" and the two posts, one of which still has the motor on, though I guess that won't be a huge
job to remove.
Krismc
posted on 8/4/09 at 08:56 PM |
If you where closer i could of lent the tools for the job, but im in newcastle!
Need anyparts im sure i can help, as thats basically my job
hillbillyracer
posted on 8/4/09 at 08:57 PM |
I bought a hydraulic/cable 2 poster & had to dismantle it, we unbolted the motor/pump from the top of the post it was on & then unbolted the
pillars & laid them down, then lifted them with an engine crane onto my trailer, the base was light enough for us just to lift ourselves.
The only real problem was the pullies for the cables stuck out of the bottom of the pillars & one took off across the floor on us as we started to
lay it down & could have been very messy but we were lucky & nowt was damaged as it fell. If you're on mechanical screw threads that
wont happen to you!
This was done with just me & a mate, looking back we were daft & it should have been a four man job.
ashg
posted on 8/4/09 at 09:43 PM |
your looking at about 300kg a side. have moved a coupe for friends and its allways taken 4 blokes and an engine crane to move them any distance.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
NS Dev
posted on 8/4/09 at 09:54 PM |
ashg, cheers, comfirmed my suspicions!!
blakep82
posted on 8/4/09 at 10:23 PM |
engine crane should be man enough to lift each post, the leg can manouver under your trailer, legs either side of the wheels, should get you sorted
i'd think?
________________________
ashg
posted on 8/4/09 at 10:40 PM |
yeah the engine lift can get it to the trailer once its on the ground but it cant un-bolt it lift it off the floor studs and lay it down on the ground
thats where the 4 blokes come in to guide it lol
the best way to move them is with a H beam A frame using a winch and pully system but the aframe its self is also a beast to move about.
