westf27
posted on 29/6/10 at 04:53 PM |
pinto camshaft
Haynes book says fit camshaft from the rear of cylinder head.Can it fit in from the front.Dont want to take the head off unless its required.
555
segan2b
posted on 29/6/10 at 05:21 PM |
Option 1
Take the head off.
Option 2
Cut a 'service' hatch in the firewall.
jollygreengiant
posted on 29/6/10 at 05:38 PM |
Option 3
Take engine out and fit camshaft.
Option 4
If still in tin top wait until gearbox removal/clutch change, then jack back of engine and remove/refit camshaft through gap between bonnet &
windscreen. (done this it does work).
If in Kit car, can the front bulkhead/instrument binnacle be removed.
Explanation ------- the front journal is smaller than the middle journal which is smaller than the rear journal.
Hope this helps.
[Edited on 29/6/10 by jollygreengiant]
westf27
posted on 29/6/10 at 06:03 PM |
I'll leave the camshaft in the garage tonight with a note for the fairies
555
