BobM
posted on 23/8/10 at 02:09 PM |
ZX10 wiring
Anyone know how to simulate the tip-over switch on the ZX10 (2007 motor)? I could always fix the actual switch to the car but neater to use a resistor
if possible.
dan__wright
posted on 23/8/10 at 02:34 PM |
yeah, i will post info shortley, i havent actualy done it but its on my to do list (currently re-wiring the whole lot) its something like 3k Ohms and
13 K ohms in a voltage divider
it also looks like it will still work ip you pop it open, remove the disk from the inside and it should work any way up.
FREE THE ROADSTER ONE…!!
Flamez
posted on 23/8/10 at 02:45 PM |
if possible.
The small switch looks quite neat IMHO
my build mac1motorsports
jossey
posted on 23/8/10 at 03:30 PM |
http://locostbuilders.co.uk/viewthread.php?tid=141054
dan__wright
posted on 23/8/10 at 03:37 PM |
i wish the wiring was that simple! thats the old carbed version, the 06/07 is dfi and has tons of extra bits to worry about.
zilspeed
posted on 23/8/10 at 04:11 PM |
Ye olde ZX10 really is quite simple, isn't it ?
dazzx10r
posted on 23/8/10 at 07:33 PM |
I have the original owners manual for 04/05 and 06/07 on cd if you need a copy, they have good in depth wiring diagrams on there and tell you how to
use the clocks on board diagnostics.
BobM
posted on 23/8/10 at 08:22 PM |
Thanks for that - I have the workshop manual with that info in it, I hadn't realised it gives the specs of the voltage output for the switch -
it's all in the FI section and I was looking in the electrical bit. Turns out the ECU's looking for 0.65-1.35V on the yellow/green
wire.
I'm presuming I can't access the on-board diagnostics without the clocks (which I don't have)?
Not very Locost but very BEC
dazzx10r
posted on 24/8/10 at 10:35 AM |
wire.
No mate, the clocks read a sereies of pulses, which you count out to give you a fault code, but i'm sure someone will have come up with a locost
solution to reading the codes without the clocks, check out zx10r.net there may be more info on there for you.
