Author: Subject: raceline water rail
chris666
posted on 16/11/10 at 06:23 PM Reply With Quote
raceline water rail
Whats the best setup when it comes to the raceline water rail?According to raceline no expansion/overflow bottle is needed,and on warmup there is alot or water coming out of the overflow.is this normal on the 1st run?
Chris
Tiger Super Six
posted on 16/11/10 at 06:29 PM Reply With Quote
I ran mine without an expansion and it did push water out. Then when you ran it again no further water was pushed out.
As a bit of a check I used to then pour the water back in from time to time and make sure that the same amount came back out again, which it did.
HTH
Mark
Tiger Avon
chris666
posted on 16/11/10 at 06:32 PM Reply With Quote
Out of interest, what temp do you have your fan cutting in at?
Chris
posted on 16/11/10 at 06:42 PM Reply With Quote
I used one for a bit, what a nightmare!
The thermostat is too far away from the head to work properly.
I did a track day in October 2008 and ran all the way home in the dark up the A19 with the choke out!
Waste of good money, reverted back to the Ford housing with a aerial pole from b&q and its been solid as rock ever since!
r1_pete
posted on 16/11/10 at 07:39 PM Reply With Quote
This setup worked perfectly, the cap on the raceline rail is a plain non pressure cap from an Austin 1100, the header tank cap is the pressure releif.
enginedone
enginedone
big_wasa
posted on 16/11/10 at 09:18 PM Reply With Quote
HTH
I do the same with mine.
big_wasa
posted on 16/11/10 at 09:20 PM Reply With Quote
I would use the standard stat housing if I could fit it in the chassis.
austin man
posted on 16/11/10 at 09:52 PM Reply With Quote
toy dont need the raceline one if fitting in a seven as there is plenty of room at the back of the engine for the ford unit
posted on 17/11/10 at 08:39 AM Reply With Quote
The problem with the thermostat is they didn't design a by-pass into the remote housing. The best remote thermostat is the Landrover TD5 thermostat (part number PEM100990 also used on the last MG TF and Rover 75 1.8 models) this fits into the bottom hose and forms a by-pass via a T piece inserted into the top hose.
This type of thermostat has special design features that will keep the engine temperature rock steady without hot or cold spots forming in the engine.
posted on 17/11/10 at 08:43 AM Reply With Quote
To quote "Mr Punch" That's the way to do it ! :-)
A not quite so good way to do it is use and pressurised cap on the the water rail and non presurised expansion bottele from a Japanese car or Honda engined Rover.
Tiger Super Six
posted on 17/11/10 at 09:20 AM Reply With Quote
Chris
Cuts in at just over 90.
Mark
Tiger Avon
chris666
posted on 17/11/10 at 08:07 PM Reply With Quote
How big does the hole in the thermostat need to be,that race line says to needs there.
Chris
[Edited on 17/11/10 by chris666]
posted on 18/11/10 at 07:05 PM Reply With Quote
The hole in the thermostat will form the only by-pass it works to an extent but is an awful bodge the engine temp will go up and down like yoyo and you will get hot and cold spots in the water jacket.
For an external thermostat the Rover/LandRover PRRT is the best solution it opens under both temperature and flow temperature, and it is cheap.
