posted on 1/1/11 at 04:29 PM |
u2u linky no worky
if you search for a member, the little 'send u2u' link doesnt work on the profile page. You have to pick a post by them and send a u2u via
that.
Not the end of the world but worth knowing about for next time you're looking at the code chris!
this being the url that says file not found:
http://www.locostbuilders.co.uk/members/JoelP/u2u.php?action=send&username=JoelP
[Edited on 1/1/11 by JoelP]
chicade
posted on 1/1/11 at 04:31 PM |
my search still isnt working properly either
posted on 1/1/11 at 04:44 PM |
i read your other thread. So if you click on the search icon above, the one below the car banner, and type in 'hairynuts' (as one word),
in the 'search for' box, how many results come up? Should be just one.
If you get loads of result, you could try to look through all the posts and see what word it is actually searching for!
chicade
posted on 1/1/11 at 05:12 PM |
yes it is just one........but if i search for electric reverse i will get thousands of results all in date order and 99% of the results dont have
anything to do with my search, i have tried searching for various stuff, its only the last few days i have had the problem, used the search function
loads before and although a little slow sometimes its always been quite specific and accurate. something has definatley changed???
posted on 1/1/11 at 05:25 PM |
you are correct, when searching multiple words, it seems to be searching individually for them. So your search for 'electric reverse'
throws up all thread with 'electric' in, and also all with 'reverse'.
ChrisW
posted on 1/1/11 at 05:42 PM |
that.
I've fix this, Joel. Thanks for pointing it out!
Chris
posted on 1/1/11 at 07:46 PM |
no messing about there
