Author: Subject: Phoenix repaired and back
jeffw
posted on 20/2/13 at 08:28 PM Reply With Quote
Got my car back from Fury Sportscars who have done an excellent job putting my axle back together after the trailing arm mount detached itself at Snetterton. All the mounts have been drilled out to 1/2" and all the 12mm bolts replaced. Rear drums have been sorted out (one slave wasn't even working) and the axle has been banded/gusset and reinforced, it also has adjustable rear arms so I can play with the angle of the nose of the diff. Lots of other bits and pieces and the car is now ready for the season.
Car weighed in at 643Kg with 35l of fuel onboard. More than I was expecting but there is a lot of gubbins with the supercharger.
Some pictures
engine
New towstrap....if you have it you'll not need it
gussets !
more gussets
Big Tyre
New mirror extensions
Nick DV
posted on 20/2/13 at 08:44 PM Reply With Quote
Looking good Jeff. When are you at Goodwood next?
Cheers, Nick
"The force will be with you, always!"
jeffw
posted on 20/2/13 at 08:48 PM Reply With Quote
Sometime in April I think....27th off the top of my head. If it is dry I hope to be sub 90sec.....if I can get under 88secs it would be really good
Furyous
posted on 21/2/13 at 07:19 AM Reply With Quote
What size are your rear tyres? I've got some 225s for mine but I'm not sure if they're going to fit under the standard wheel arch.
INDY BIRD
posted on 21/2/13 at 08:33 AM Reply With Quote
The fuel alone prob weights 35 o 40 kg and yes ll those bits to get extra power add up I did on my turbo conversions, especially when you dry sump them aswell that extra oil ads a few kg,
Still I think you have plenty of power to over come it seen the video looks rapid on the straight,
Nice car
Sean
jeffw
posted on 21/2/13 at 02:51 PM Reply With Quote
The tyres are Avon ZZR 215/60 13" on 8" rims. They are actually closer to 235mm hence why they look so large.
The fuel would weigh 35Kg or so therefore the car comes in at 609Kg without fuel. 340BHP seems sufficent to move it forward in a 'meaningful' manner
matt_gsxr
posted on 21/2/13 at 04:10 PM Reply With Quote
Petrol has a density range of 0.71-0.77 g/ml.
If you have the densest petrol then 35litres will come to about 27kg.
If you are fueling with water then it will weigh 35kg.
jeffw
posted on 21/2/13 at 04:42 PM Reply With Quote
Pedant
A pedant is a person who is excessively concerned with formalism and precision, or who makes a show of his or her learning.
Of course, Matt, it wouldn't go anywhere without fuel hence it is a silly thing to do without....
Nick DV
posted on 25/2/13 at 02:28 PM Reply With Quote
Look forward to seeing you and the car then.
Cheers, Nick
jeffw
posted on 25/2/13 at 03:28 PM Reply With Quote
Is yours finished yet then?
jeffw
posted on 25/2/13 at 03:59 PM Reply With Quote
New 1300 series prop is on its way from D&F which will be the last bit of the old transmission left.
