chesney321
posted on 14/12/14 at 05:35 PM |
front indicator positions
I am about to do the lighting on my car could you give me where to put the indicators on the nose cone.i know they have to be a certain height but is
there a distance from the tip of the nose cone...any help will be appreciated
Dooey99
posted on 14/12/14 at 07:38 PM |
http://westfield-world.com/svalights_front.html
hope this helps
Less weight more speed, more power more speed
If in doubt, give it a clout
The Black Flash
posted on 14/12/14 at 10:54 PM |
...you need to make sure they are visible from certain angles as well. Careful of the inward visibility - you must be able to see the left one from
45 degrees over to the right, and vice-versa. If you mount it too far back on the nosecone then it won't comply. So, no set distance back from
the front, but you need to make sure you can see it from all the specified angles. I notice that many production cars don't seem to comply with
this, annoyingly.
Diagram on p 168 of the pdf below, text on p 185:
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/354071/M1_IVA_inspection_manual.pdf
[Edited on 14/12/14 by The Black Flash]
