Monty2556
posted on 16/4/15 at 07:34 PM |
PCV 1600 xflow
Following advice on this forum I installed a catch tank on my 1600 xflow. Disconnected the pipe to the inlet manifold and blocked it off. Routed the
crankcase breather to one of the catch tank unions and the other catch tank union vents to atmosphere. Do I still need a PCV?
posted on 16/4/15 at 08:26 PM |
I used a breather take off from Burtons which replace the breather filter on the side of the block and connects directly to the catch tank with no PCV
in the system . If your using a standard manifold just block the breather connection.
johnemms
posted on 17/4/15 at 08:56 AM |
You use a nice new PCV valve & oil separator tank if you are running a standard single carb & manifold setup.
If you are using a twin 40 type manifold..
Remove the insides of the PCV as it is no longer required & use it as a connector to the oil separator.
Route its pipe into your rocker cover - all the blown oil and vapour will go back into the top of the head not into a catch can.
You now need to take a separate pipe from the rocker cover to a catch can for the vapour & fumes.
(If you only take a pipe from the crank to a catch can it will fill up very quickly)
Hope this helps.. :p
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
posted on 17/4/15 at 06:26 PM |
I haven't had to empty my catch tank in nearly 6 years , I doubt it even has 1/4pint in it in that time. If you are using an electric fuel pump
fit a deflector type blanking plate
steve m
posted on 17/4/15 at 07:33 PM |
My crossflows run a pipe from the crank case to the rocker cover, and a seperate pipe from rocker to catch tank
Seems to of worked fine so far
steve
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Monty2556
posted on 17/4/15 at 08:05 PM |
Thanks for all your advice thus far.
