MadMaxx
posted on 11/10/17 at 05:59 AM |
Installing Quaife ATB in Sierra 7" diff
I'm installing a Quaife ATB in 7" Tripod Sierra diff, but there in some interference with the case on the left side. Is it normal? How to
solve it? Is there a trick or do I have to grind to enlarge the opening?
My re-building diary:
http://www.llcc.it/YetAnotherForum.NET/default.aspx?g=posts&t=13448
Dick
posted on 11/10/17 at 06:56 AM |
Some fit some dont so as you say out with the grinder to the casing to get it in.
gaz_gaz
posted on 11/10/17 at 06:57 AM |
yep the interference is normal .
in order to get the ATB into the housing you have to file a small chamfer to the inside back of the left driveshaft hole in the casing.
MadMaxx
posted on 11/10/17 at 06:59 PM |
After your confirmation, I will grind, hoping it will be necessary only a little bit.
