Phil. S
| posted on 14/1/06 at 01:59 AM |
Avatar problems
I know this has been covered before. I've done a search and tried what people recommend. But I can't get my bl***y avatar to work
Any suggestions? Its the v.small hullavington pic in my picture archive.
| posted on 14/1/06 at 03:36 AM |
Spot the difference! the first is the link you should be using, the second is the one you are using! Unfortunately cos it includes the https they are
both live links, but if you just copy the first into the avatar url box then it will work.
http://www.locostbuilders.co.uk/upload/MSE%20Hull%20111105%20V1%201532%20vsmall.jpg
http://www.locostbuilders.co.uk/www.locostbuilders.co.uk/photos.php?action=showphoto&photo=MSE%20Hull%20111105%
[Edited on 14/1/06 by JoelP]
Phil. S
| posted on 14/1/06 at 10:26 AM |
Cheers Joel,
Do you think it is too big?
| posted on 14/1/06 at 10:30 AM |
fractionally, but not scandilously
mines too small though...
flak monkey
| posted on 14/1/06 at 10:32 AM |
General rule was 250px wide. Yours is 300px. Change it if you can be bothered, if not wait until someone complains.
[Edited on 14/1/06 by flak monkey]
Sera
http://www.motosera.com
RazMan
| posted on 14/1/06 at 11:13 AM |
quote: Originally posted by Phil. S
Cheers Joel,
If you reduce it to 250 pixels wide it will improve the quality a little (less jagged edges)
Raz
907
| posted on 14/1/06 at 03:33 PM |
I would have thought 5 cms was plenty.
Surely it's the content of the post that's the important bit.
Half the screen taken up with avatars is OTT, IMHO.
Paul G
Phil. S
| posted on 14/1/06 at 05:27 PM |
Now 250pixels. It seems the smaller I make it, the more pixelated it becomes. Don't know why. I started with a high res photo.
RazMan
| posted on 14/1/06 at 06:10 PM |
Which prog did you use to reduce it's size and which file format? That might have a bearing on the jaggies.
Raz
Phil. S
| posted on 14/1/06 at 06:50 PM |
It's a jpg file, and I used the software that came with the Olympus camera called Camedia. Would it be better in a different format?
Sorted. Saved original as btm file, shrunk it in Paint program, then saved it back to jpg. No jagged edges, and the right size. Thanks for you
help.
[Edited on 14/1/06 by Phil. S]
RazMan
| posted on 14/1/06 at 06:57 PM |
Some of the camera software have some strange ways. If you use Corel Draw you can export the pic to a jpg and choose the resolution as well as image
size.
If you email the original pic to me I will sort it for you if you like.
[Edited on 14-1-06 by RazMan]
Raz
Phil. S
| posted on 14/1/06 at 07:27 PM |
Thanks for the offer, and for the help, but it is sorted out now, to my satisfaction at least.
RazMan
| posted on 14/1/06 at 07:30 PM |
No problem - looks good now anyway
Raz
mad-butcher
| posted on 14/3/06 at 09:01 PM |
thanks guys don't know how I did it but managed to get the avatar up and running, mine was the massive address as JoelP says so I just cut the
upload/ part off the bottom of the pic and tagged it onto the locostbuilders/ url and it works
many thanks
tony
