flyingkiwi
posted on 1/2/06 at 05:41 PM |
Alternator Light
Hi Guy's,
Question for you;
I've just wired up my dash and plugged it into the main loom. Everthing is working as it should bar the Alt light. When the ignition is off the
light comes on. As soon as you turn the key to on, the light goes out. I've double checked my loom to the haynes manual and I'm missing
the, I have no idea what its called, bit between the alternator and instrument cluster.
Any idea what that is and where abouts in the loom it is and can I buy/scrappy one?
This is really bugging me,
Chris
It Runs!!!!! Bring on the SVA!
flak monkey
posted on 1/2/06 at 05:48 PM |
Its a diode so that current can only pass one way. Hence why your light is coming on at the wrong times.
Other than that, I cant help much. Someone will know where it is in the loom though.
Sera
http://www.motosera.com
johnjulie
posted on 1/2/06 at 06:38 PM |
Depends on the type of alternator you have fitted, some need the diode, some don't. Hence the choice of link or diode in the diagram.
Cheers John
flyingkiwi
posted on 1/2/06 at 07:57 PM |
I'm thinking I've got the alt that needs the diode. Any idea's as to what type of diode and can I get them from Maplans?
Chris
Dusty
posted on 2/2/06 at 12:45 AM |
The dash light should connect to terminal 61 on the alternator and via the ignition switch to battery positive. It should not have a live feed at
either end with the ignition switch off, diode or not.
In the posted diagram there is no live feed to the instrument panel with the ignition off and the light is between terminals 7 & 8. With the
ignition on, live feed is in through 7, through the light and out through 8 to the alternator where it runs through the rotor windings to earth thus
completing the circuit. A diode won't help, it must be wired wrong.
flyingkiwi
posted on 2/2/06 at 01:54 AM |
hmmm, tricky. The light is correctly wired to the alt plug, as it uses a common live feed and the other lights work perfectly. The only thing I can
think of now is that somewhere near or in the alternator there is a spurious permament live feed from the alternator up the blue wire, thus when the
ignition is on the two feeds equal and cancel each other out (hence the light turning off).
Will have another closer look at the alternator and its wiring tomorrow. Just out of pure chance, the alternators off an escort and I'm running
sierra loom. Any chance that might have something to do with it?
Cheers for all the help, keep them ideas coming!
Chris
hmmm anyone recommend a good supplier of alternators (cheap?)
tri
posted on 2/2/06 at 06:44 AM |
Had this problem on a Fiesta and traced to faulty alternator. Bought a reconditioned one.
Regards,
Tri
posted on 2/2/06 at 10:25 AM |
thus when the ignition is on the two feeds equal and cancel each other out
Wouldn't that be a short circuit? Have you got a good earth on your instrument panel?
[Edited on 2/2/06 by Peteff]
splitrivet
posted on 2/2/06 at 11:28 AM |
The lamp earths via the alternator Pete.
If youve got a multimeter or test lamp take the connection off of the alternator and check that your getting 12v when you switch on the ignition if
not your wiring is incorrect, if you are you probably need the diode, Maplin part No QL73Q or similar will do it cut the wire and solder the diode in
WITH THE WHITE END NEAREST THE ALTERNATOR insulate it up and off you go.
Hope this helps.
Bob
posted on 2/2/06 at 01:17 PM |
Yes I know....
I wired mine up using Sierra dials. What I mean is if it's fed via the dash and receives a live feed from the other end it is then a short
circuit. I find earths are usually the culprit when faults like this show up, if he hasn't then something else may be earthing via the ignition
light.
splitrivet
posted on 2/2/06 at 03:32 PM |
light.
Aah yes see what you mean,trouble with using original looms is sometimes they run out of a particular colour cable then joint it at either end inside
the loom and use a totally different colour in the middle
Bob
[Edited on 2/2/06 by splitrivet]
flyingkiwi
posted on 2/2/06 at 07:32 PM |
I agree with that, many a times I've come across a wire that changes colour mid loom.
Will try the 12v test tomorrow, got a feeling that I need the diode as all the switched earth lights (oil, park/brake and alt) are feed of a common
live and all of them work bar the alt light. Will also look into why there is a 12v feed coming from the alternator.... hate this leckie stuff.
