RK
posted on 20/2/07 at 01:08 AM |
steering rack for LHD
I am in Canada. We drive on the right as does the majority of the world, although here in Quebec a lot of people tend to drive on the left - just for
fun I guess.
Silly question I have yet to find an answer for:
Can I use an Escort rack from the olde country and flip it over to use as a left hand drive?
DavidM
posted on 20/2/07 at 01:33 AM |
You can, but the wheels will turn the opposite way to the steering wheel.
It might take some getting used to!
RK
posted on 20/2/07 at 01:48 AM |
Might not pass inspection then, is what you are saying.
How about a BMW Mini LHD rack? Would that fit a regular book frame without modification? Welding the rack is a no no here, so I am trying to avoid
that, as well as avoid spending $400 US for one from a frame maker.
[Edited on 20/2/07 by RK]
tks
posted on 20/2/07 at 06:11 AM |
mhhh
i would just buy a quick ratio one from the UK..
its then new, and saves the hassle of reinventing the wheel..
www.raldes.co.uk
Tks
locostv8
posted on 20/2/07 at 07:52 AM |
You might want to get on http://locostusa.com/forums/index.php and do a search for "rack".
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
bartonp
posted on 20/2/07 at 10:29 AM |
Cheap + nasty = u/j the steering wheel over to the 'wrong' side!
tks
posted on 20/2/07 at 10:37 AM |
yeah!!
lets do that!!
or get a bearing and 2 sprockets
and a bit of chain!!
Tks
macnab
posted on 20/2/07 at 10:50 AM |
TheGecko
posted on 20/2/07 at 11:08 AM |
To get back to some sort of sensible
Why do you want to use an Escort rack? Do you have a set of Cortina (or Stellar) uprights and you're building exactly to the book? If not then
why torture yourself. There are a vast multitude of vehicles with R&P steering out there. Work out what size rack you need to fit the chassis
you're building and the uprights you're using. For instance, in my mid-engined car, I'm using a Gemini (Chevette to you) rack
because; I'm using Gemini uprights; and it fit's my (wide) chassis design. The only real trade-off is the lack of fast-ratio kits like
the Escort one has.
So, state your donor details and ask the question again.
Dominic
alfasudsprint
posted on 20/2/07 at 12:00 PM |
or use a chevette rack, quick racks available. not sure of canadian model name though...
miegru
posted on 20/2/07 at 12:48 PM |
in my opinion you want a quick rack on a seven and I don't think they come any cheaper as the escort ones that Rally design sell (mention
earlier by someone). I have used them on both my sevens and can only recommend them.
I'm sure you need more stuff so if you buy in one go the extra transport cost shouldn't be too bad.
