rusty
posted on 24/7/07 at 10:21 PM |
Radiator cap flange
Can anyone point me in the direction of a supplier of a brass radiator cap flange that I can silver solder on to other piping as required.
RazMan
posted on 25/7/07 at 08:09 AM |
Car Builer Solutions do an alloy version if that helps
Raz
posted on 25/7/07 at 09:53 AM |
just unsolder one from an old rad with blow torch
Also take one of the stub pipes from the rad using the same method.
Then solder the stub pipe to the base of the flange to give you a simple method of connecting it to a "Tee" fittling usinf bit of rad
hose.
