nige
posted on 6/11/03 at 09:35 PM |
picture under name
new to this
the forum has been good to us
and very helpful as we start a tandem build tried to put a pic under name
failed miserably
help!
Ben_Copeland
posted on 6/11/03 at 10:06 PM |
it has to be hosted on the internet, before it'll show it. It's pointing at your harddrive atm, which wont work !
Stick it on the Locost Photo Archive
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 7/11/03 at 12:55 AM |
Pictures...
As Ben says but don't forget to use an external link... something like:
http://locostbuilders.co.uk/
then whatever directory and file it is...
then all should be fine...
nige
posted on 7/11/03 at 12:29 PM |
picture under name
thanks boys i,ll give it a try
posted on 8/11/03 at 01:45 PM |
Avatar
Rash,
Put the picture you require into your photo archive first this is essential. Make it a maximum of 200 pixels wide so it fits into the locost margin
under your name. This bit is pretty easy.
Once this is done, goto the photo in your photo archive and copy the URL on the top address bar. This is actually the external lik you require. Paste
this in it's entirety into the avatar link within your locost control panel. Then all should be well and your picture should appear!
Regarding the animation I have on the website - and formerly on here, I made it myself. I got a picture from off the net, I altered it to what our car
will look like, then animated it all. Took a while but worth it, due to the response I get!
If you see a pic u like, and would like it animating. We could talk...
posted on 8/11/03 at 01:54 PM |
Rash,
I put an animated picture in my archive for you to experiment with called gargoyle.
Copy the image to your PC. Upload it into your archive then follow the link to that!
http://www.locostbuilders.co.uk/photos/showppic.pl?file=gargoyle.gif&archive=Hellfire
Hope it explains...
nige
posted on 8/11/03 at 06:49 PM |
name under pic
hellfire
did just as you said but still only get a
little red cross, i think the link is there but
no pic
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
posted on 8/11/03 at 11:51 PM |
I'll check it out then post the link...
posted on 8/11/03 at 11:58 PM |
Link
Rash&Nige,
If you type the following URL into your avatar, it will work!
http://www.locostbuilders.co.uk/upload/gargoyle.gif
Enjoy
To alter it simply alter the gargoyle.gif to the filename of your choice...
