Mix
posted on 29/4/08 at 04:27 PM |
Ignore posts
I think there was a discussion recently which highlighted a facility to 'ignore posts by poster', I can't find it now, am I having a
senior moment or does this facility exist?
Regards Mick
graememk
| posted on 29/4/08 at 04:44 PM |
is it me ?
Dangle_kt
| posted on 29/4/08 at 04:45 PM |
quote: Originally posted by graememk
is it me ?
If it is, and he found the feature, then he will never know you replied.
| posted on 29/4/08 at 05:28 PM |
Presumably it's something similar to a newgroup kill list??
Not sure if it happens...
Go on. Spill the beans
graememk
| posted on 29/4/08 at 05:31 PM |
errrm "MIX" under my name it say Contributor yet under your name it impies that you masterbate, how did you do that and why?
Quote "Mix Tosser"
[Edited on 29/4/08 by graememk]
tks
| posted on 29/4/08 at 06:05 PM |
Quote "Mix Tosser"
maybe Chris changed this, so that he spents the money to change it...
| posted on 29/4/08 at 06:24 PM |
Quote "Mix Tosser"
you're going back a long way there!
http://www.locostbuilders.co.uk/viewthread.php?tid=7596
mookaloid
| posted on 29/4/08 at 09:07 PM |
Regards Mick
There's an Ignore list in the U2U window bit if that's what you are looking for
Mark
UncleFista
| posted on 29/4/08 at 11:02 PM |
I think it was a suggestion/request for an "ignore user" function, it was never real
I know I'd use it, the signal to noise ratio can get a bit high here sometimes
Tony Bond / UncleFista
