mad-butcher
| posted on 26/9/08 at 06:47 PM |
multiple images in a topic
evening
How do you post multiple pictures in the one post
many thanks
tony
[Edited on 26/9/08 by mad-butcher]
Paul TigerB6
| posted on 26/9/08 at 06:54 PM |
7th button along above where you type your message - "insert an image". Add pics using that leaving an empty line between each
[Edited on 26/9/08 by Paul TigerB6]
blakep82
| posted on 26/9/08 at 07:03 PM |
[img]blah blah blah[/img]
like how you insert a photo in one post, but mutiple times
etc etc
[Edited on 26/9/08 by blakep82]
________________________
| posted on 26/9/08 at 08:22 PM |
as above, easiest method is to do it manually (as the vicar said to the actress, fnar fnar fnar)
just [img] address [/img]
Humbug
| posted on 26/9/08 at 09:09 PM |
I know that works if you link to other pics on t'internet, but does it also work if the pics are on your local hard disk? i.e. when the poster
logs off does it keep a copy?
| posted on 26/9/08 at 09:49 PM |
No!
bimbleuk
| posted on 27/9/08 at 06:25 AM |
I use either photobucket or the photo archive on here. Create your post and in another browser window or tab have your pictures already open. The
correct image code is available in both instances to just cut n paste across below each picture.
