Jenko
posted on 5/10/08 at 08:17 PM |
Clearout sale...
Just having a clear up of my shed, and have the following up for grabs...
Free postage on everything:
*Crossflow Pressure plate, and clutch (used, but not done much mileage) - £13
Crossflow clutch pic
*Set of Hydraulic lifters for a CVH engine - Used but in good condition - £15
Lifters
*32mm adaptor for a temp sensor (goes in line with the coolant hose) - Ideal if you are fitting Megasquirt / Fuel injection, and do not have a temp
sensor - SOLD
Temp sensor adaptor
*3 switches - Washer, windscreen wiper, and Fan - SOLD
Switches
*Set of brand new ignition leads to fit ford Coil pack (electronic ignition), and the smaller size plugs (Fit's CVH, but would fit many other
cars). - £15
Ignition leads
*GSXR600 Air box - Perfect for using the trumpet holes to attach a back plate for an air filter. - £15
Air box
*Megasquirt additional VR sensor cct, for use on Megasquirt when two VR sensors are required. £10
VR sensor cct
*Spare wheel bracket from a westfield -SOLD
Like this one
[Edited on 6/10/08 by Jenko]
b4ldd
posted on 5/10/08 at 08:36 PM |
U2U sent spare wheel bracket
MikeR
posted on 5/10/08 at 11:07 PM |
If the clutch / pressure plate are for the type nine then i'm interested (i know you said crossflow but you didn't say the gearbox)
CaptainJosh
posted on 6/10/08 at 06:50 AM |
U2U sent for 32mm adaptor
Jenko
posted on 6/10/08 at 10:04 AM |
U2U's replied....
Apologies......Yes, clutch and Pressure plate were attached to a type 9....Also the pressure plate fingers are the 'wavey' type!....I
remember burton describing them as that whan I bought it :-) both did around 6 k miles in the westfield....
