Hi,
By the sounds of things,this weekend is going to be a manic one!With a shedload to do!
One of these tasks is going to be the handbrake,mounting it into the car,has anyone got some photos of how they did theirs please?
I found one photo,but im looking to lower it,by about 4 inches so that it doesnt look as if i have a flag pole in the car!
Would this just be a matter of fabricating a plate and welding it in 4 inches lower in the tunnel?
[Edited on 8/1/09 by maskell01]
Wouldn't that foul the propshaft?
Chris
Bugger, to tell the truth,that slipped my mind!
Mac#1 raise the tunnel and recess the H/B lever so its inside the tunnel when not in use.jpg)
It's not that obvious from pic, but I used a Toyota MR2 handbrake mounted to the side of the tunnel. It's out of the way and works really
well.
[img][/img]
I actually like the side mounted idea since it gives more room for your arm to rest whilst driving. Mine is in the tunnel (half in half out).
Hi
Mounting it on the side is by far the easiest option.Also stops you swearing every time you bang your elbow on it when changing gear. I am pretty sure
that the majority of ST cars had them on the side if looking for inspiration. But a MG metro maestro handbrake comes to mind as being what they
used.
Personally i use a ford but have to re bend the mountings. Then just bolt it to the passenger side of the tunnel with spacers and a alloy cover made
to fit around / over it.
Cheers Matt
