Hey all, just wondering, how much different is the westfield chassis to the book 1? Also, wat kinda stuff do u need to do the chassis to make it IRS? Cheers
Are you intending to weld your chassis together or buy one?
weld: shouldnt be too hard but will take a lot of time (ask james about moding the chassis)
Buy: if you buy you can get an irs chassis for 500-1000 pounds no effort and leaving yuo loadsa time to get cracking on your donor car. companies to
look into are luego, mk, gts, mac1, to name a few.
There doesn't seem to be an "standard" IRS design, Checkout de dion (nearly as good as wishbones) - dozracing does a kit, checkout the
tiger avon book by Jim Dudley. Eventually a "best practice" or de facto standard will emerge, meanwhile home chassis builders do what seems
right to them & (hopefully) live with it!
I'm now committed to wishbones but if I were starting again I'd probably do de dion.
cheers
Bob C
CJ
Another thing to do is buy the Tiger Avon book (and a tub of glue to stick the pages back in with) and graft their IRS onto Ron Champion's
"locost" plans.
That's what I've done!
Simon
Guys, someone out there must have a tried and tested design for an IRS set up. Im looking to go this way with my first attempt with a sierra donor. Any pictures or sketches?
first you will have to chose standard width or a plus 4
the plus 4 plans i have used have come off mcsorleys site they are very good i beleve this suits the wider sierra track but others will disagre
the irs i have used is a mix of the avon and my own it takes ages to do anything your self and get it right so i would advise the de dion set up as it
looks easy to fit and a very good compromise
if you do go your own way it takes 5 times as long to get anything you will be happy with
good luck dave
Scoop
This may seem a silly question but why do you want to go IRS? Are you going to track race your car?
Why IRS - to be honest tracks tend to be smooth enough for a truck axle to work OK! IRS = low unsprung weight which comes into its own on rough
surfaces. SO you win cornering on bad roads. I have an mx5 & it is a heap better with OZ superleggera wheels in place of same size MIM wheels.
Only difference, about 1kg per corner. So I'm OTT about unsprung weight on my '7' - I'm even worried about the unsprung weight
contribution of cycle wings at the front !
cheers
Bob C
Hi All
Most of you shy away from making your own IRS and I wonder why.
Wishbones arn't a problem. Top one is the same as the front on mine ( and RC's prototype ). A few bits of box to brace the dif area is not
rocket science. Dif mounting plates I think you can buy if not make, ( I did make my tranny tunnel to fit the dif ).
So it's down to uprights then, it certainly was the bit that made me scratch my head. I made a profiled plate that fits the Sierra brake
backplate, drilled & tapped to fit the drive shaft, on which could be welded mountings for the W/B's & shock.
(See my photo archive for finished, fitted item.) This was just a loose copy of the plate on the Sierra axle.
If something like this was commercialy available would it solve a problem? (for those who havn't got access to a profile cutter)
I'd like your thoughts on this one.
type 907
suspension is genrally a bastard subject.
its full of angles, geometry, techniques and pitfalls.
There are specialist books written on the subject alone. KPI, camber, ackerman, roll centre, blah de blah all are in there to screw up your
design.
I went with IRS and its added months to the build.
the original seven used irs. Trawl this site and others to see if you can find the statement
'my live axle locost handles like crap - im gonna convert to irs'.
In 3 - 4 years on the net using sites like this its NEVER come up as an issue.
IRS sounds like a nice idea - but unless your gonna race (is irs race legal?) I wouldnt bother.
If you are gonna drive so hard on the road that you think you need IRS, look at Alez recent post to see how easy it is to trash a car.
Think hard before you go IRS - It can add complexity, masses of time, and in the end you may end up with something WORSE in terms of handling than a
std book live axle.
atb
steve
I was talking to some of the Guys at DAX who incidentaly can sell you either an IRS or DeDion Chassis, about which set-up to go for. The long and the short of it was as previously said an irs system only comes into its own in race situations. A drawback with IRS is when pulling away from a stand still: The car squats and cocks up all of the rear geometry just when you want maximum rubber on the road. That problem is non-existent with a Live axle system. I think beam axles are still used (front and rear) on some American oval racers but i might be wrong about that. So unless you intend to get the extra that IRS gives you by racing your locost save your time and effort and keep with the old fashioned Live / dedion set-up
I think live axle and de Dion are perfectly fine, and have only started to look at IRS in order to use 500+ lbs/in bike shocks. These would have to be
mounted inboard in order to put leverage on the shock.
I am thereby adding needless time and complexity to my build, but WTF?
This should be a picture of a Leitch with inboard shocks:
excuse my ignorance, but whats a leitch?
looks rather tasty, do you have any more pics?
ta Al.
pete, i like that pic of the donkey. would that style of suspension be 5 point or does the spring counts as a 6th point? looks pretty tidy anyway.
point remains anyway, make a choice and do any! pros and cons all round.
Hi again
Just to clarify a point or two:
I'm not saying that IRS is better, I'm certainly not saying my version is better than any other IRS, Dedion or conventional axle.
I just get pleasure out of building it. If it takes longer to build or ends up as being slower, or handles worse than others I don't mind,
"it's mine". If I can help anyone along the way, that too is a bonus.
I definitely won't be racing it, I'm to old for that.
Paul G
If you choose to do IRS it can only help to have a nice cut plate available, so i think its all good myself. a good offer anyway paul, if i ever
upgrade my car i'll give ya a shout!
Wouldn't try that at home!
i did irs on my car cos i wanted it to be different.
I wouldnt do it again.
atb
steve
being different i chose to do irs at the first attempt that means a lot longer build/wait to get on the road without much of a noticeable benifit when
it gets on the road ( and the more i learn about suspension the more complicated it gets and i wont know if mine is ok until its on the road)
if i were to do it again dedion would be my choice
cheers dave
cheers dave
Gotta agree there.
James
