Headlight mounting
Dave Bailey - 9/3/09 at 11:19 PM
I need to mount my headlights and have made some ally brackets to mount them. I need to attach these to the chassis and the easy way is with rivnuts. The problem is that 6mm fixings need a 7.98mm hole in a 26mm box section. Welding studs would make a mess of my nice paint job. How many people have used rivnuts?
Dave B
tomgregory2000 - 10/3/09 at 07:41 AM
ive used rivnuts and my 6mm nuts needed a 9.5mm hole
chris_smith - 10/3/09 at 08:05 AM
^^^^what he said
but iv used them all over my chassis with no problems
chris
Mr Whippy - 10/3/09 at 10:34 AM
hope you've used substantially thick aluminum? as I mounted some chrome driving lights on to a 5mm thick aluminium panel and the damn things cut a perfect 2 inch hole round the mounting point due to the lamps vibrating and fell off
Dave Bailey - 10/3/09 at 12:17 PM
Thanks guys... I may have to re-think the thickness of the ally plate but at least I can get it mocked up! Thanks again for the advice!
Dave B
