My chassis is nearly ready for paint and i was wondering, how long did it take you to get from a bare, painted chassis to an SVA ready car?
That is a very spurious question!!
Are all of the panels pre-bent? Are all of the bones/bushes etc assembled? Has the bodywork been chopped and finished and ready to bolt on?
well i havent made any of the bodywork yet but im just after a rough idea.
... I started in 2004 I think, still not done
i think you should change you poll from weeks to months!
does it really take that long? I thought it was just a case of bolting everything together and making the body work.
It won't take that long if 1 week = ~39 hours work on the car
but in real life, I know of at least one dax thats 9 years and counting = ~468 weeks
(and he bought the chassis, suspension and body)
as for me, I ordered mine at stoneleigh in 2005 and I'm still building, but Alex got his after me an has been on the road for ages.....
[Edited on 25/3/09 by mcerd1]
i think you should change you poll from weeks to months!![]()
It took me 6 weeks to get from this to finished.
Working all day every day......
Checkout my post back in October
http://www.locostbuilders.co.uk/viewthread.php?tid=99531
[Edited on 25/3/09 by dogwood]
I rechassised mine and it still took 5-6 months to build and assemble, this did include making new panels and working out a megasquirt
installation.
ATB Dan.
it took me 14 months to get my car from chassis to sva'd and on the road, for the first half of the build i was working nights so had all day to work on the car, then started new job and the build slowed sown a bit.
depends how you do it. Personally I bought my chassis over a year ago and its still got nothing bolted to it.
a) I only get home to work on it 1 or 2 weekends a month
b) cash prevents progress on certain avenues
c) I specced a weird selection of parts so I have now stripped 2 complete donors and nearly every part has to be electrolysed, cleaned, sprayed
etc.
If you bought a chassis with all the mounts to build a book locost, bought the wishbones, uprights etc froma refurbed supplier I bet you could do a
standard book 1300 quite nicely in 2 months.
I voted more.
Much, much more.
I got my chassis 18/10/06, failed SVA 12/5/08 and passed re-test 27/5/08, Registered 1/6/08. So thats 17 months.
Or are we talking weeks of actually working on the car, ie. 168 man/hours= 1week? In which case, it was about 4-6 weeks.
adrian
[Edited on 25/3/09 by adithorp]
I bought mine part-built (rolling chassis)in feb '04 and passed SVA feb '09!
I had to strip it right back and start again as previous owner had totally bodged the ally panels etc.
I only worked on it one or two weekends a month and didn't touch it at all for 18months while I had an extension/bigger garage built. there were
further times when I wouldn't work on it for a few months or so. In fact, if it wasn't for the imminent arrival of IVA giving me the
necessary kick up the backside, it would probably be sat in the garage now waiting for me to finish it!
hi
i painted my chassis on 5th jan this year and got my sva test on the 7th april
still working all week
only work on the car evenings and weekends
cheers
colin
i bought my chassis in 2003... not really much more than a rolling chassis at the minute. however, engine is sort of in (needs a bit of adjustment to get the engine mounts in right) gearbox mount needs some help, all i need for the axle is my side gears re-cut (hopefully...) electrics, plumbing, and should be good to go...
Bought the house in early 2000 & started the welding course.... collected bits from then on...
still not completed the chassis, but i'm damned close
the car has undergone some changes - like de-dion rear end and changing the rear end to look more caterham.
Its a labour of love (and boy do i hate it at times).
Placed deposit For chassis kit on 27/10/2004.
Collected kit ................................22/01/2005
Moved house ........................... May 2005
Extension over garage started Jan 2006
MILFH's occupation off garage till Sep 2006
Work began in earnest on kit October 2006
working on it a few hours each week when possible.
SVA passed 23/03/2009
I found that the chassis was the easy bit, the rest of it was a lot of fabrication. I'd say that the chassis took 1/4 of the total time. That said, it depends on what you buy and what you make.
Total 450 hours over 3 years.
including 6 weeks to strip donor and 10 months cleaning all the donor bits, slowly.
Then 2 years building.
Took me 42 hours to fully make the chassis, and 640 hours to do the rest!
Change it from weeks to months
I went from a pile of steel to a rolling chassis in a couple of weeks, then another three years to get on the road.
Where it stayed for ten months, until I took it off the road to add some turbos, and where it still is 2 1/2 years later!
Simon
