Is it possible to bend square tubing using the: fill with sand, stuff ends with rags then heat and bend method?
Or will it distort significantly?
If that's not possible, does anyone know how MK do their's?
Thanks,
James
I think its done in a machine,easier to cut into the sides of the tube,bend and re weld
ps precky sunday?
James,
Try this www.tubela.com.
Bet thats how MK do it.
Thanks,
James
one thing I have seen is diy hydraforming...this guy got a pressure tester for comerical pluming (rented) that is a hand pump for like 1500 psi, he
welded up a flat stock exspansion tank for a dirt pipe with a bung on one end then pumped it up into shape. he use a hammer to kinded help shape it.
I could see where a sinilar setup could work. bend tube with heat then "inflate" it.
nick
Hi
When MK bend sq section tubing it is done on a machine but even then the inside of the bend kinks into the tube so you don't get a true bent sq
section if you know what I mean. Still looks nice though.
Chris PTM
Chris, FYI it's more than likely that the MK bending inside die/former has a deliberate ridge that forces the inner face to go inwards in a controlled
fashion, seeing as the kinking of the inner face is unavoidable. IIRC the procedure is called "crush bending", you see it a lot on bent square tube
furniture.
It's about 15 years since is was involved so my recollection may be a little hazy
Have a look next you see Martin, if only for my sanity
Alan
