Apologies if this topic has been covered but Ive searched and cant find it !
Which is the better chassis the Haynes Roadster or Ron Champions or are they the same.
I have only purchased Chriss, Haynes Roadster book. I dont know if theres a difference. Do I need Rons book ???
I am querying this having read 'cymtriks' 'Analysis of a Car Chassis' and the modifications he suggests may improve stiffness etc.
Only he references to Rons book and the part nos dont tally !!
Are his mods relevant to the Haynes Roadster or is the Roadster an evolution of Rons with issues ironed out and stiffness improved.
Can the double Y bracing still be implemented in the same way to increase engine space ??
Totally different designs.
Ron's is based on a MK2 Escort, using Cortina front uprights and a live rear axle.
Chris' is based on the Sierra as a donor, is slightly bigger and uses independant rear. It's also been designed using computer software and
is a stiffer, stronger chassis.
If I was building again, it'd be a Mr Gibbs design I'd be building
I take it you've found the Haynes Roadster Forum ?
[Edited on 16/7/09 by UncleFista]
I have built a book car and am very pleased with it, but if starting now I would build a Haynes, you don't have to raid Beaulieu to get your
donor parts, and Triton makes a very good and reasonable body panel kit.
Chis is very approachable if you want to make modifications on here and http://www.haynes.co.uk/forums/index.php
Go for it, you won't regret it
I am querying this having read 'cymtriks' 'Analysis of a Car Chassis' and the modifications he suggests may improve stiffness etc. Only he references to Rons book and the part nos dont tally !!
i must admit that i haven,t read the Ron Champion book but i,m approx 50% through building a Haynes Roadster, what appealed to me with the Roadster is
that it is a more up to date design, as already mentioned, designed with computer drawings for strength, using independant rear suspension etc, there
are quite a few "builds in progress" at the moment & various engines are being used , 1.8cvh,zetecs & V6,s, all of which are fitting
into the chassis,s without major problems, also as the Haynes Roadster uses sierra running gear some of the donor parts are easier to get hold of.
i might add that i,ve never built a car before & have found Chris,s book very easy to follow.
good luck with your choice.
cheers
andy
With Rons book, now, you only have the book.
With Chris Gibbs/Haynes you have the book and the website, infact you need the website as it goes hand in hand with the book and the info is concise
and spot on.
Another vote for haynes
Originally posted by Ninehigh
I thought they were both the same, the latter being modified for lack of mk2 escorts and giving up one the £250 price tag..
Is there really that much difference?
Doh, deleting one of a double post deletes both of them!
Looks like there's so much difference in them all calling it a Seven is getting like calling any van a Transit...
