I have already posted this in the body work bit, but it realy belongs here.
The torsion stiffness of the MGF is not great
MGF Torsional Stiffness: 7100Nm/degree
BMW Z3 Torsional Stiffness: 5600Nm/degree
MX-5 (mk1) Torsional Stiffness: 6000Nm/degree (approx)
MGTF Torsional Stiffness: 8500Nm/degree (est.)
BMW Z4M Torsional Stiffness: 14500Nm/degree
and I would like to remove the windscreen, which adds a fair chuck the it.
So, if I get rid on the screen, how can I make up for the loss in stiffness (insert gag here), and also increase it?
As it will be maily for the track, I want to fit a rollover bar, and I have already got a set of TF body braces to fit
Linky to webpage
So, how do i add strength?
Where would be the best place to add some bracing?
The MGF isn't that bad... even your linky page says "Stiffest roadster in its class at launch - and surprisingly remains competitive
even now".
Re your question, without any engineering qualifications mind
, I would have thought if you remove the screen hoop (yellow) you should replace it
with something that joins the at the same points, say some roll bar tubing with small bends at each end welded to the top of the A posts? Imagine the
bar at the front of a roller coaster car. Then you could fill in the gap from where the bottom of windscreen glass used to be to the top of the new
bar with an aeroscreen of some sort. Then put a braced roll bar at the back.
...or, braced roll bar at the back joined to the top of the existing screen frame?
Weld the doors shut.
I have no problem with welding the door shut, not sure how much that would help.
I was thinking that the strengthening piece that goes under the dash could be made stronger, with some bracing pieces across to the place where the
screen was.
I'm liking that avatar.
thats the kinda thing
my rough scetch.
Gonna give it some thought.
I am in no ruch
do you need the passenger seat?
Just thinking a petty strut would help, or even petty strut to the top of the dash structure that you're going to make.
(id make the aero screen out of steel to make it into a stressed member to replicate some of the strength of the windscreen)
There are some more ideas on your linked website here
e.g.
I suspect the windscreen contributes very little to the stiffness of the MGF since it's not tied into a roof. Just like a locost, the big empty
cockpit area will likely be the limiting factor.
Also not sure why you consider the standard torsional stiffness is "not great" when it beats it's competitors of the era by a decent
margin?
To put it in perspective a RonC book locost was calculated to be somewhere between 1200 to 1400 ftlbs/degree (1600-1900 Nm/degree) by cymtricks. While that can be increased considerably with his proposed mods the MGF as it stands is 2-3 times stiffer out of the box.
Thats a good point, well made.
I will definately give the scren some thought.
I really do like the red concept car thingy. Just a little too gay for my liking, but it still gives me the horn
the mgtf has bars across the lower part of the front subframe, and across the the rear engine compartment, and a strengthed piece under the dash.
I have already aquired these bits.
they also have solid subframe mounts instead of rubbery ones.
i think the screen could help somewhat - but i've no idea how much.
If you've got a very rigid square thing and you add it to the top of an open structure + mount it over a small distance, say 6 to 12". It
will add some strength.
If you've got a very rigid square thing and you add it to the top of an open structure + mount it over a small distance, say 6 to 12". It will add some strength.
I kinda figured that, but they are supposed to do a job.
webby
I got the info from the above site.
What I need is someone who knows their stuff to tell me that I can get rid of the screen, and can mke the chassis more ridged, by added a braced
rollover bar at the back, and some cross bracing from A to B, around the front dash area.
Been thinking about the torsion strength thing today while at work.
Would doing things like, fully welding subframes (as apposed to them just being welded in places) add ant ridgidity?
Or things like removing door skins, and bonding riveting panels over?
Just thoughts these tho, as I'm cluesless as to what really makes the chassis ridged.
Would I be right in thinking the main problem area in the car would be the door area?
Are you going to have a passenger?
If not, petty strut it.
make a balsa model and you'll soon realise you lose a lot of strength in open areas.
If you're going to do the doors, weld both sides so you have a tall box rigidly added to the structure not a thin sheet of metal. Should be a big
improvement.
The point i was making about hte screen is that if you solidly weld in a 6" member across the open space it will beef it up a lot. I was gessing
hte screen structure would be solid (ish) and the load as it meets the car would be over a few inches. If you replace that with something you
won't be losing out too much.
(I've no idea what the scuttle is made out of so this could be worthless idea).
eeeerrrm got me there
