Wanted to know if anyone has pics or knows how to join a rear midened chassis to the rest.
You midengined chassis is basically a subframe, I would bush it with resilliant bushes and bolt it to the body/rest of chassis using prefabbed
brackets. This will reduce vibration and make maintenance a lot easier.
Does your barchetta have a separate chassis? If it does, it would make it even simpler (less complicated!!)
I am basically thinking of using the rollcage as the main frame, being it one long tube going all the way to the A frame area. The engine and gearbox plus wishbones would be connected to as you say subframe. Not sur eweather it is worth building a front subframe as the car is very short.
Rollcage would be... sufficient... but a backbone and rollcage would be a lot stronger.
Where is your gas tank and radiator going to go?
How would you attach your front suspension without a subframe, or are you talking about having front frame and mid frame be one piece?
Are you going to go racing?
-MR
yep both front and mid one piece. Tank up front and rad behind like the audi rally from the 80s.
So, why would you need or even want a front subframe?
The fewer pieces you have, the fewer there are to break.
-MR
