mt75 mounting
Is it OK to weld the piece in the picture on the left underneith the chassis? Or should I look for bolting options?
Normally I prefer bolting because it is easier if the rubber needs to be exchanged.
Unfortunately I cannot get the existing hole to line up with something.
Another option would be to make a strip with welded nut to use instead of the part on the right. Then weld a strip underneith the chassis and use a
Land Rover engine mount.
Any ideas?
[Edited on 25/8/09 by maartenromijn]
Ive welded my mount in. Now its all panelled its a pain to get the engine and box in and out.
Weld on some plates that will line up with the holes.
Duncan
i would prefer to bolt anything like that just for ease in the future. You may find that if its welded it may be in the way at some point in the future. When i changed my clutch i dropped the box out of the bottom of the tunnel which you wouldnt be able to to.
Duncan
I think its a diesel landrover heavy duty mount. Ive used them for the engine aswell.
A strip of steel 10mm thick welded to a square of metal 6mm thick.
It was then drilled and tapped to take the m10 stud and welded on top.
Next time I take the engine out I will modify it so that the plate can bolt in.
Its so much harder to swing the engine and box over it.
Chep and very solid and sell for £2.75 new over here.
They do stop the engine and box from moving about which is good as you say there is very little room.
Duncan
Duncan, I would have to re-route the lower tranny tunnel sections.
Would it be OK to bolt through the hollow sections instead? I would not prefer that because of weakening the construction AND water ingress causing rust.
mt75 is a tight fit in standard locost....
You may also be interested in how I modified the the rev switch ? I also had to chop of the extra casting lumps that stick out. Gives you an extra
20mm
If you're going to bolt through the chassis tubes I would weld on some re-enforcing plates to make up for the lost strength and use sealant around the bolts/washers to try to keep the water out.
Looking at your pic again, could you mount two strips, one in front and one to the rear of the current mounting holes and then re-drill the mounting plate in front and to the rear of the rubber bush (it looks like there might be enough room and you would probably have to trim the existing holes off). The two strips could then be bolted to small welded plates on the outsides of the tunnel (IE inside your footwell area)
It may be complex but anything would be better than welding it in.
Duncan
You may also be interested in how I modified the the rev switch ? I also had to chop of the extra casting lumps that stick out. Gives you an extra 20mm
You can bolt through the chassis tube but worth lining them with a bit of tube of suitable size to
a) seal them from water ingress
b) add some lost strength
Put a block of ali in and solid mount it.
