Does anybody know where I can get a 50mm lenght of threaded tube for a top wishbone?
ebay ? If you need it for your Luego then Matt at Casarva on ebay may be able to help
I just discovered that Lolocost do them for £4. Job done, thanks anyway.
Note that you'll still need a tap to get the threads to an acceptable state after welding (and even prior to welding unless lolocost have improved their quality control recently!).
once the weld's penetrated through, the thread's had it. i had to run a tap down mine.
